Disable AI assisted chat in iTerm2Solved
6 months ago Oct 03, 2025
Hello,
I have macOS devices enrolled in Hexnode UEM, and we are using iTerm2 instead of the default Terminal app (the domain is com.googlecode.iterm2). All devices currently have AI-assisted chat enabled, but due to security reasons, we want to disable AI assist in iTerm2. We have over 100 macOS devices, so we hope to achieve this via a script or configuration deployment from Hexnode. I have tried a few scripts and config profiles, but they didn’t produce the desired result. Does anyone know how this can be done?
6 months ago Oct 05, 2025
Hi,
You can disable AI assisted chat in iTerm2 using a configuration profile. Save the following code as a .mobileconfig file and deploy it to your macOS devices via Hexnode’s Deploy Custom Configuration policy.
Once the policy is successfully applied, quit and reopen iTerm2, the AI-assisted features will be disabled.
Note: Replace REPLACE_WITH_UUID with actual UUIDs before deploying the profile.
If you encounter any issues while implementing this, feel free to reach out.
Ben Clarke
