Can administrators be alerted based on device conditions?Solved
8 months ago Aug 10, 2025
Hey, I’m thinking of the ways in which an administrator can be alerted based on device conditions? For example, what kind of conditions could trigger an alert, and how would that be set up?
Replies (8)
Are you referring to enrollment-related events, or more to compliance issues?
Honestly, both! Anything that could be marked as an issue.
8 months ago Aug 11, 2025
For compliance-related stuff, there’s actually a section in the policy tab called Compliance Policies. Worth checking that out.
Hey there @boris, welcome to Hexnode Connect!
You can absolutely set up alerts to notify administrators when devices become non-compliant, or even send emails for various device events.
For compliance, Hexnode can mark a device as non-compliant under several conditions, like:
  • MDM app/profile is removed from device
  • Device becomes inactive
  • Device is not encrypted
  • Device is not password compliant
  • Device is not application compliant
  • Device moves out of geofence
  • Device is jail-broken
  • Device is not CIS-compliant
The available compliance options depend on the platform in use. You can set up compliance policies under Policies > Compliance Policies.
Additionally, under the Admin > Notifications tab, you can configure notifications to alert administrators for a variety of events, including when a device is enrolled, disenrolled, exits kiosk mode, when the device’s battery level drops, or when lost mode is activated, to name a few. These notifications help keep administrators informed about key device activities in real-time.
You can refer to our help documentation on compliance policies and setting up notification alerts via emails.
8 months ago Aug 12, 2025
That’s super helpful, thanks! I just have another question, what if a device starts using an unusually high amount of data? Can that be flagged?
For iOS/Android devices, you can manage mobile data usage via policies. You can set a threshold, and if the data usage exceeds that limit, an admin can be notified.
Check out our help documentation on managing mobile data usage on Android and iOS devices.
6 months ago Oct 16, 2025
I have recently had an issue where I during macOS Updates being pushed I had several devices which failed the update process, and it took me a little while to figure out that the update failed due to insufficient storage space to download the OS update.  Can we not get a Hard drive high water mark alert?
Hi @amorris,
Thank you for reaching out. You can create a compliance policy to monitor available storage and trigger alerts when it drops below a set threshold.
To set this up, head to Policies > Compliance Policies > New Policy > macOS > Advanced Settings, select Available Internal Storage under the column field, choose the appropriate comparator (e.g., “less than”), and enter the desired value.
After saving the policy, navigate to Admin > Alert Profile > New Alert Profile, set the Event Source to Device, and add the event Device Out of Compliance. Choose your preferred notification method (e.g., email), assign the relevant devices or user groups, and specify the technicians to be notified.
This setup ensures you will receive alerts when storage is low, and the device becomes non-compliant, allowing you to take action before macOS updates fail. We hope this is what you had in mind. Do give it a try and let us know if you need any further assistance.
