Set Different Wallpapers on Home and Lock ScreenSolved
4 weeks ago Feb 16, 2026
I want to set different wallpapers for the home screen and lock screen on my iOS devices. Is that possible in Hexnode?
Hi @timo-liam
Yes, you can set different wallpapers for the home screen and lock screen by configuring the Wallpaper feature within Policies. Within that policy, you’ll have the option to select separate images for each screen, or you can choose to apply a single wallpaper to both. Please note that this feature works only on supervised iOS devices.
Hexnode UEM
It worked! Thanks, @simon_scott .
Hey @simon_scott ,
Can I do the same thing on Android devices?
Hello @gnishilda
Currently, Hexnode supports setting up different wallpapers for the home screen and lock screen on iOS and Windows devices. For Android devices, you can set only a single wallpaper, and it will be applied to both the home screen and the lock screen.
Okay. Got it.
