Reached device enrollment limit, need help enrolling more devicesSolved
4 months ago Dec 10, 2025
Guys
We’ve reached our device enrollment limit in Hexnode, and now we’re blocked from enrolling additional devices.
What’s the best way to proceed here? Are there options to manage existing enrollments, so we can add new devices?
Yep, once the license limit is reached, new enrollments won’t go through. At that point, you either need to add more licenses or remove existing devices from the console to free up licenses.
If you’re planning to reuse licenses, make sure the devices are properly removed so the system releases them.
Hi @pauel,
Thank you for reaching out. To free up licenses and enroll in new devices, there are two practical paths you can consider here, especially since wiping isn’t an option.
Method 1:
Another method is that if you don’t have any inactive to remove, one option is to purchase additional licenses and then reassign the device to a fresh license. This helps rule out any edge cases where the existing license state may be contributing to the issue.
Method 2:
  1. Disenroll devices from the console
    1. Go to Manage > Devices.
    2. Select the device(s) which are inactive or lost.
    3. Click Actions > Disenroll device. Once the device processes the command, you can enroll in more devices.
  2. If the disenrollment remains pending (for example, if the device is offline or already reset):
    1. Navigate to Reports > Disenrollment pending devices
    2. Select the device and click Mark as disenrolled
Please note that Mark as disenrolled immediately removes the device from the console without confirmation from the device. This option should only be used when the device is already reset, lost, or unreachable, as the device may become locked if it later comes online. After the device is removed, the license will be freed instantly, allowing you to proceed with new enrollments.
Feel free to reach out if you need help reviewing your licenses or device list.
Cheers,
John Cooper
