How can I exit kiosk mode on my Windows device, and is it possible to use remote view while the device is in kiosk mode?Solved
1 day ago Mar 18, 2026
I’ve applied a kiosk policy to my Windows device through Hexnode UEM, and now the device is locked down in kiosk mode. How can I exit kiosk mode when I need to, and is it possible to use remote view while the device is in kiosk mode?
Kiosk exit i guess it’s available in hexnode but about remote view, i am kinda doubtful.
21 hours ago Mar 18, 2026
Thanks for raising the question.
  1. To exit kiosk mode on Windows devices, you have two main options:
  • From the Hexnode UEM portal:
  • Disassociate the device/user/group from the kiosk policy under Policies → Policy Targets.
  • Or remove the kiosk policy directly from the device/user/group under Manage → Devices/Users/Groups.
  • Alternatively, archive the kiosk policy, which automatically disassociates it from all devices.
  • Directly on the device:
  • Press Ctrl + Alt + Del and sign out of the kiosk account.
  • In multi-app kiosk mode, you can also sign out from the Start menu by clicking the user icon. (This option isn’t available in single-app kiosk mode.
For more informationdo refer: How to exit kiosk mode on Windows devices?
  1. Regarding your second question on remote view in kiosk mode:
In multi-app kiosk, remote view is possible, but you must add Hexnode UEM and the Hexnode Remote Assist App as background apps in the kiosk configuration for it to work.
