Enrollment – Work account creationSolved
4 months ago Dec 14, 2025
Hi, I need to create a work account on my Android device. Any ideas as to which enrollment type I should use? There are options like Device Owner, Profile Owner, and several others linked here: https://www.hexnode.com/mobile-device-management/help/enroll-android-mobile-devices-hexnode-mdm/
For a work account, you can use Android Enterprise – Profile Owner enrollment. This setup is designed for users who want to keep their work and personal apps separate.
4 months ago Dec 15, 2025
Thanks, I tried it out. But while enrolling, I got this message on the portal “Work account creation failed”. Has anyone seen this before?
Hi @ryanmoore!
No worries, this error is temporary. The message “Work Profile creation failed” may pop up initially, but the issue should resolve itself after a short while. The work profile may take some time to be created after the device enrollment is completed.
Once the work profile is successfully created, an additional Hexnode for Work app (with a work badge on the icon) will appear on the device. This indicates that a work container has been set up on your device, separating work apps from personal apps.
To confirm the work profile installation, you can also go to Settings > Accounts. You should see a “Managed Account” listed under your work profile.
Let us know if it works after a few minutes!
Regards
4 months ago Dec 16, 2025
Got it, thanks! I’ll wait and check again.
