Display attributes in the portalSolved
2 weeks ago Mar 24, 2026
Hi everyone, is there a way to view attributes like phone numbers, IMEI numbers, etc., all at a glance in the portal? Right now, I have to open each device individually from the Manage tab, which takes a bit of time.
2 weeks ago Mar 25, 2026
Hey! You could try grouping devices using custom or dynamic groups based on those attributes. That might make things easier to track.
Thanks for the suggestion! I’m not really looking to group or sort devices, I just want to quickly see those details together.
Hi @skylar-a,
You can customize the columns in the Manage tab to display certain device details in the list view.
Follow these steps:
  1. Click on the pencil icon in the Manage tab.
  2. Select the attributes you would like to display, such as Phone Number.
  3. If you don’t see the column right away, try scrolling horizontally, it may just be out of view.
You can also remove any unnecessary columns to better organize your view and make important details easier to spot.
2 weeks ago Mar 28, 2026
Just checking, are there any limitations on which attributes can be added as columns?
Hi @harold,
There are a set of fields (visible when you click on the pencil icon) that are supported as column options. If you don’t see a specific attribute listed, it means it’s not currently supported for column display.
That said, feel free to share the attributes you would want to see, and we would be happy to pass them along to our team as feature requests.
