Checking Personal Device Eligibility for Microsoft 365 Conditional Access and App DeploymentSolved
3 months ago Jan 01, 2026
I am trying to find the documentation that explains how to check whether a device meets conditional access requirements for Office 365, and then use Hexnode to push required applications to those devices. I want to make sure the device eligibility is validated first before any apps are deployed. Can someone point me to the right resources?
Hello,
Thanks for reaching out. I understand that you are looking to verify device status before proceeding with application deployment, especially in conditional access scenarios.
To check whether a device is properly registered and eligible for Microsoft 365 conditional access, you can refer to the following Hexnode documentation, which explains how to verify Microsoft Entra ID device registration status directly from the Hexnode console.
Once device eligibility is confirmed, you can use Hexnode’s Required Apps policy to automatically deploy the necessary Office 365 or related applications to those devices. This ensures that approved apps are installed consistently after the device meets the access conditions defined by your identity and compliance requirements.
If you need help tying these steps together in your workflow, feel free to let us know.
George
