Wi-Fi hotspot under peripheral settings not working as expectedSolved
5 months ago Oct 28, 2025
Hey everyone! I wanted to share something we have encountered with Android 16 devices in kiosk mode.
When we try to enable the Wi-Fi Hotspot through the peripheral settings, it turns on but immediately turns off again. However, once we exit kiosk mode, the hotspot stays on and works as expected. We have noticed the same thing happens when the ‘Enable status bar’ option is turned on in the peripheral settings.
Thought I’d mention this in case anyone else faces the same issue, and maybe we can find a solution here!
Replies (6)
That’s an interesting one. Have you checked if there are any blocked packages under the Applications tab of Hexnode portal? Sometimes those can mess with the hotspot feature.
5 months ago Oct 29, 2025
Checked, nothing’s blocked. I wish I could show you guys the device, haha! But basically, the device shows the message ‘Please wait while verifying’ and then it enables the hotspot normally. In kiosk mode, though, that message doesn’t even appear, and I can’t turn it on at all.
From what I found online, that message usually comes from the network carrier, it appears while verifying the connection before enabling the hotspot. You could try using a SIM from a different carrier or connect to Wi-Fi before turning on the hotspot.
5 months ago Oct 30, 2025
Wow, that worked! Connecting to Wi-Fi before enabling the hotspot did the trick, thanks.
This is likely due to the SIM carrier. In some regions, using the hotspot requires an additional subscription.
5 months ago Oct 31, 2025
Gotcha!
