Where can I find the Hexnode Store?Solved
4 months ago Dec 08, 2025
Hey everyone!
I was checking out some posts in here and came across this one about the Hexnode Store: https://www.hexnode.com/forums/topic/hexnode-store-what-is-it/
It sounds pretty useful, but I can’t seem to find it anywhere in our portal. Does anyone know exactly where this feature is located?
Replies (6)
Hey there! The Hexnode Store should normally show up under the Apps tab in your portal.
Well, I went ahead and checked the Apps tab, and found Hexnode Store to be greyed out.
Hi @amelia,
It looks like you are currently subscribed to a plan lower than the one that supports the Hexnode Store feature, which is why the option appears greyed out in your portal. You will need to upgrade to a higher plan to avail the feature.
4 months ago Dec 09, 2025
Ahh, that makes so much sense now. Thanks a lot for looking into it!
4 months ago Dec 10, 2025
Hi, what if someone doesn’t have access to the Hexnode Store, is there any kind of alternative you would recommend?
Hi @remi,
Yes, there’s definitely an alternative you can use!
If the Hexnode Store isn’t available on your plan, you can still manage and deploy apps using the Local Apps section under the Apps tab.
Check out our help documentation on setting up app inventory.
