What to do with the Encrypted but Unprotected Status?Solved
3 weeks ago Mar 03, 2026
Hi everyone! We have two Windows devices showing the BitLocker status in the Hexnode portal as Encrypted but unprotected.” I found this article: “Protect Verification Key for BitLocker Encryption” suggesting we might need to modify our Windows policy to address this issue.
However, we’re worried that changing the policy might mess with our other devices that are already showing as “Encrypted.” We also can’t figure out why only these two machines are acting up while the rest are fine.
Does anyone have advice on how to fix this without impacting the whole fleet?
Replies (6)
@zariah , Did you verify whether the devices are encrypted from the settings?
@douglas , How do I do that? Is it from the device end or is there any way to check it in the Hexnode portal?
@zariah , You need to check at the device end.  On the affected devices, navigate to Settings > Privacy & security > Device encryption (or System > About on older versions). Check if the Device encryption toggle is set to On.
@douglas , the device encryption is toggled on, no problem, but the status in the portal is still unprotected.
Hello @zariah , If you found that the encryption is already enabled in the device settings, please follow these steps to resolve the “unprotected” status:
  1. On the devices: Manually disable the “Encryption” setting.
  2. In the Hexnode portal: Re-associate the Windows policy with the devices to trigger a fresh handshake. You can find various methods to do this here: How to associate policy.
This force-applies the BitLocker policy. Once done, check the device status again in the Hexnode UEM portal to see if it is encrypted and protected as expected.
Elle Reed,
Hexnode UEM.
@elle_reed , now the status is encrypted. Shows the same at the device end too. Thanks!
