What is self-healing automation?Solved
2 months ago Jan 20, 2026
Hey everyone,
I’ve been hearing a lot about self-healing automation in UEM lately. Sounds great in theory, but does it actually work in real-world environments? Or is it just another buzzword?
2 months ago Jan 21, 2026
It’s definitely not just a buzzword.
Self-healing automation basically takes routine troubleshooting off your plate. Instead of waiting for someone to notice an issue, the system automatically detects, diagnoses, and fixes endpoint or configuration problems.
2 months ago Jan 22, 2026
In a typical UEM setup, if a user disables something critical (like disk encryption or removes a corporate app), the device stays in that non-compliant state until someone notices and fixes it. So instead of periodic audits, you’re maintaining continuous compliance.
2 months ago Jan 23, 2026
That makes sense. So is this something that works automatically out of the box, or do you need to configure it?
You do need to configure it properly. Usually, it’s built around things like policy drift detection, automated actions (like reinstalling apps, re-enabling settings), or triggers based on device state or compliance.
Once those are set up, it runs in the background. That’s where the “self-healing” part really kicks in.
2 months ago Jan 24, 2026
And honestly, once you start using it, going back to manual troubleshooting feels painful.
