What is regex?Solved
3 days ago Mar 21, 2026
Regex? I keep hearing this. What is it actually, and what do people use it for?
Replies (7)
At its core, regex (regular expressions) is used to match patterns in text. You can use it to detect specific formats, extract data, or validate inputs that follow a defined structure.
2 days ago Mar 22, 2026
Yeah, think of it like a shortcut. Instead of manually going through text, you define a rule like “anything that looks like an email” or “device names starting with FIN-” and regex picks it up.
Jumping in here, don’t let the syntax scare you! It looks like a cat walked across a keyboard at first. [a-zA-Z0-9._%+-]+@[a-zA-Z0-9.-]+\.[a-zA-Z]{2,} is a classic one for emails.
1 day ago Mar 23, 2026
Wow, sounds like I’d have to dive a bit deeper into this. But how is this actually useful in a UEM setup?
21 hours ago Mar 23, 2026
From a UEM perspective, regex is less about theory and more about control and precision. Whether it’s grouping devices, filtering logs, or picking which devices a script should run on – all of this works under regex.
15 hours ago Mar 23, 2026
Also worth noting, it’s not something you need every day, but when you do, it saves a lot of manual effort. Especially in large environments.
7 hours ago Mar 24, 2026
I agree with @roger. Regex is one of those tools that feels optional, until you start scaling. Then it becomes a shortcut for tasks that would otherwise take hours.
