Restricting iTunes Store Access via Hexnode PolicySolved
3 months ago Jan 07, 2026
Hi everyone, I’m trying to figure out how to restrict access to the iTunes Store on iOS devices. We don’t want employees downloading apps outside of what’s approved. Does Hexnode have a way to block this?
I’ve been wondering the same thing @eliiza . We’ve got a mix of older and newer iPhones, and I’m not sure if the restriction works across all versions.
Great question, @eliiza and thanks @jennifer ! Here’s how you can manage iTunes Store access via Hexnode UEM:
  • Navigate to PoliciesiOSBasic RestrictionsApplication Settings in the Hexnode portal.
  • Locate the iTunes Store option.
If the option is checked, then access is allowed. Else, the access is restricted. The above setting applies to iOS 4.0+ devices, and on supervised devices running iOS 13.0+.
Clara Sterling,
Hexnode UEM.
Thanks a lot, @clara_sterling ! That clears it up perfectly.
Appreciate the detailed explanation, @clara_sterling. That really helps us understand how to handle our mix of devices.
