Re-enable Hexnode Service on Windows?Solved
3 months ago Dec 18, 2025
Hey everyone! Quick question about Hexnode on Windows—if an end user somehow disables the Hexnode service on a device, can it be re-enabled automatically, or does it have to be turned back on manually?
3 months ago Dec 19, 2025
@skylar-a , no worries there! End users don’t have the ability to directly disable the Hexnode service on a Windows deviceand this applies to IT admins as well. Even if the service were to stop for any reason, it automatically comes back up when the device is restarted. So, there’s nothing you need to manually intervene for.
 Got it, thanks for the clarification, @kylian_parker !
