Okta integration just got a makeover!Solved
8 months ago Aug 07, 2025
Hello everyone!
We’ve got some exciting news – our Okta integration just got a sleek upgrade! No need to panic – we’re not dropping support. In fact, we’re making things easier for you.
With our upcoming Hexnode update, we’re streamlining the Okta integration by shifting from the old API token method to a more secure and simplified Client Credentials flow.
What you’ll need to do:
  1. Add the Hexnode app to your Okta admin console.
  2. Grab your Client ID and Client Secret from Okta.
  3. Use these credentials to reconfigure your integration within Hexnode.
Points to remember:
  • You won’t be able to modify existing Okta configurations using the old method.
  • Your current Okta setup will still work as it is – no disruptions!
  • But if you need to make any changes or want access to future Okta updates (including the upcoming Okta Device Trust feature), you’ll need to reconfigure using Client Credentials.
Need detailed info? Check out our help document for a complete walkthrough.
Still have questions? Drop us a line at support@hexnode.com or connect with us on Hexnode Connect.
Ben Clarke
