More Flexibility, Less Hassle: Meet Custom AttributesSolved
4 months ago Dec 17, 2025
Got data that doesn’t quite fit into standard fields? We have got you covered!
With the latest addition of Custom Attributes in Hexnode UEM, you can go beyond predefined fields and add your own metadata to devices, users, device groups, and user groups.
What’s New?
  • Flexible Metadata: Add custom fields to Devices, Users, Device Groups, and User Groups to capture data unique to your organization.
  • Immediate Availability: Attributes are live as soon as you create them, and their values can be used as wildcards across the portal.
  • Streamlined Setup & Control: Choose from two easy creation options:
    • Single Attribute: Quickly define one attribute at a time.
    • Bulk via CSV: Upload a CSV to create multiple attributes at once, ideal for large deployments.
  • Manage Attributes: You can edit, delete, or remove all custom attributes directly from Admin > Custom Attributes in the Hexnode UEM portal.
For more information, refer to the help documentation on Custom Attributes. Got any doubts? Connect with us here, or send an email to support@hexnode.com.
