Managed Macs not appearing in AirDrop discoverySolved
3 months ago Jan 07, 2026
Hi all, I’m hitting a wall with our managed macOS fleet. We use Hexnode to manage about 50 MacBook Pros. I’ve confirmed that AirDrop is enabled in the Advanced Restrictions section of our policy, but for some reason, these Macs cannot receive files.
My users can send files from their managed Macs to unmanaged devices perfectly fine, but the managed Macs never show up as an available destination for anyone else. Any ideas on what I might be missing in the policy?
@desmond , Have you checked the local discovery settings on the Macs themselves? Sometimes even with the policy applied, the OS defaults to “No One”.
Try going to “Control Center” at the top right corner of your device and enabling AirDrop”Also make sure that the visibility is set to “Everyone”. I had a similar issue last month and toggling that manually on the device fixed it for us.
Thanks for the suggestion,  @eduardo . I just tried that on two test machines: manually set them to “Everyone” and even toggled Bluetooth off and on. Unfortunately, they still aren’t appearing on the network as recipients. It seems like the receiving side of AirDrop is still being blocked somewhere.
Hello @desmond  and  @eduardo ,
While the Advanced Restrictions policy ensures the AirDrop feature isn’t blocked by the Hexnode, the discovery mechanism relies on a specific network protocol to function.
The reason you can send but not receive is likely due to the Bonjour (Multicast DNS) service being filtered or disabled on the managed devices. For a Mac to be seen by others, it must be able to multicast its presence over the network.
To fix this, please follow these steps:
  1. Enable Bonjour Multicast: Within your Hexnode policy, ensure that Bonjour Multicast is enabled in Advanced Restrictions for macOS devices to facilitate peer discovery.
  2. Verify Firewall Rules: If you are using Hexnode to manage the macOS Firewall, ensure that Block all incoming connections is unchecked, as this will kill the AirDrop discovery handshake.
  3. Force Policy Sync & Restart: After updating the policy to allow Bonjour traffic, sync the devices from the Hexnode portal and restart the Macs. A restart is often required to re-initialize Apple’s core network service for Bonjour (mDNSResponder) with the new network permissions.
Once Bonjour Multicast is active, your managed Macs should be able to announce themselves and appear as recipients in the AirDrop menu.
Elle Reed,
Hexnode UEM.
That was exactly what was missing, @elle_reed !
hadn’t initially enabled the Bonjour Multicast setting in our macOS policy, as I assumed the Advanced Restrictions toggle covered all of AirDrop’s functionality. After following your steps, the managed Macs are finally appearing as available recipients.
Everything is working perfectly now. Thanks for the solution!
