Looking for a workaround to find our devices after working shifts?Solved
2 months ago Feb 12, 2026
Hey everyone,
There is an issue at our distribution center. We have about 50 Android rugged tablets deployed for inventory tracking. The problem? My floor workers keep leaving them in the most obscure places at the end of their shifts—inside empty bins, under packing stations, stuffed in warehouse couch cushions… you name it.
Right now, I literally have to log into the Hexnode portal every single day at 5:00 PM, filter by the ‘Warehouse Floor’ device group, go to Actions > Security, and manually hit the Remote Ring command. They ring and our shift supervisor will round them up before locking up.
Is there a way to put this specific action on autopilot? I’d love it if Hexnode could just automatically trigger the ring at 5:00 PM, or maybe if a device sits idle for too long. Has anyone figured out a way to automate this?
2 months ago Feb 13, 2026
Hey man, I feel your pain. I manage the IT for a mid-sized retail chain and we had the exact same issue with our floor staff leaving inventory scanners in fitting rooms and stockroom shelves at closing time. Babysitting the console every night gets old fast.
You are definitely on the right track looking at the Automations feature! Since the native Remote Ring button is technically an on-demand admin action, you have two really cool ways to automate this depending on how your floor operates:
1. The Scheduled Script Route (Best for your 5:00 PM goal)
Instead of manually clicking Remote Ring, you can use the Automate tab to schedule the Remote Ring action to run on your Android device group every day at exactly 5:00 PM. You just go to Automate > New Automation, select Android, and use the Remote Ring under Security action block. Hexnode executes the remote action right on schedule, the tablets start singing, and you don’t even have to be logged in.
2. The Geofence / Compliance Route (Best for preventing theft/wandering)
If you ever want to trigger it based on location rather than time, you can set up a Geofence around the warehouse. If a worker accidentally walks out into the parking lot with a tablet in their apron, the device becomes “Non-Compliant.” You can set up an automated compliance action so that the second it breaches the fence, it automatically triggers an alert or even throws it into Lost Mode (which triggers a continuous ring).
For your daily roundup, definitely try the Scheduled Automation. I set this up for our retail stores to go off 10 minutes before closing, and it completely eliminated our “missing device” hunts. Let me know if you need a hand, it’s a lifesaver!
