Let’s talk about Hexnode XDRSolved
1 month ago Feb 20, 2026
Hi, I came across this post here: https://www.hexnode.com/forums/topic/introducing-hexnode-xdr/
This definitely caught my attention. Is Hexnode XDR something we already get with our plan? We’re currently on Ultra.
1 month ago Feb 21, 2026
I’m curious about that as well. Since we’re already using Hexnode UEM, it would be helpful to know whether XDR is bundled or if we need a separate quote.
Hi @clauss, and @schyler-scott,
Thanks for reaching out.
Hexnode XDR is a separate product and is not included in the Ultra license.
A few important points:
  • Hexnode XDR is engineered as a standalone solution. It does not require Hexnode UEM for deployment, configuration, or active monitoring.
  • If you are already using Hexnode UEM, XDR can integrate with it to provide consolidated visibility and streamlined management from a centralized dashboard.
If you’re considering it for your environment and would like pricing or deployment details, our support team will be happy to assist.
4 weeks ago Feb 26, 2026
I was honestly waiting for someone to pop in and start the XDR conversation. This sounds promising, especially if it integrates with UEM. What platforms are currently supported? Is Android included?
Hi @pauel,
At present, Hexnode XDR offers full support for Windows devices, while Android is not yet deployed.
If you need visibility into roadmap updates, you can check out What’s Cooking for upcoming features. For detailed release updates, please refer to the Release Notes section of Hexnode Connect.
Let us know if you have any other questions!
