Hey everyone, I’ve set up an Android TV in kiosk mode for a demo environment. The problem is, whenever someone presses the Home button on the remote, the kiosk app exits and goes back to the launcher. I thought kiosk mode should block this behaviour. Has anyone run into this issue?
Kiosk exits when tapped on the Home button for Android TVSolved
Tags
4 months ago
Dec 14, 2025
Yes, I’ve seen this. On Android TV, kiosk implementations are a bit different compared to tablets or phones. The Home button is harder to intercept because the system prioritizes it.
4 months ago
Dec 14, 2025
If you’re relying on screen pinning, that won’t work on Android TV. You need to configure the app as the default launcher. That way, when Home is pressed, it just reloads your kiosk app instead of the stock launcher.
4 months ago
Dec 14, 2025
One more note: if you’re testing on consumer Android TV devices, some OEMs restrict kiosk features.
4 months ago
Dec 14, 2025
I guess if you are stuck, rebooting the device can be a quick fix, though it’s not a long-term solution.
4 months ago
Dec 15, 2025
Okay! The simple restart thing actually worked for me guyss. Thanks for everyone’s input.
