Device locked with unknown passwordSolved
2 months ago Jan 17, 2026
I’m losing my mind here. My MacBook Pro M1 got locked through Hexnode, I used the unlock code they gave me, but the device still isn’t checking in. I can’t log in, can’t update the password, and all the actions are stuck pending. Support told me to restart, switch networks, open the Hexnode app, and sync..but nothing works. I even asked about disenrollment, and they said forced disenrollment removes it from the portal but might not execute if the device is offline. What’s the point then? I’m stuck with a useless laptop!
I had something similar with my team’s Macs. Forced disenrollment looked scary, but once we did it, the device dropped out of the portal and we could re-enroll it fresh. It didn’t fix the pending actions, but it gave us a clean slate for a new user. Maybe that’s the way forward here.
Sounds like the device isn’t communicating with the UEM at all. If it’s offline or blocked from syncing, no commands will push. That’s why your unlock worked locally but nothing else is happening. Did you check if FileVault was enabled? If so, the recovery key might be your only way back in.
Thank you all for your valuable input.
Since the device wasn’t checking in, no remote actions could execute. Forced disenrollment removed the MacBook from the Hexnode portal, but because the device was offline, those commands didn’t apply locally. The workaround is to use the FileVault recovery key if enabled, or otherwise re-enroll the device manually. Once disenrolled, the MacBook can be set up again for a new user, as confirmed by your teammate. In short: forced disenrollment clears the portal record, and re-enrollment is the path forward.
2 months ago Jan 18, 2026
So basically, disenrollment doesn’t actually unlock the device if it’s offline, it just removes it from the portal?
True, but that’s the trade-off with UEMs i guess. They need check-in to push commands. At least once it’s disenrolled, you can re-enroll and assign it to a new user.
