Copy policy configurationSolved
3 months ago Dec 20, 2025
Hey folks! I manage multiple teams, and many of them use the same app setup. Is there a way to copy an app configuration from one profile to another instead of recreating it every time?
Are you looking to copy the entire policy, or only the app configuration within a policy?
3 months ago Dec 21, 2025
Just the app configuration part of the policy.
For example, we have a standard configuration for our Sales team, and I’d like to reuse it for Support and Operations while keeping everything consistent.
Hi @reggie,
For your requirement, you can clone an existing policy by clicking the Clone option located right next to each policy under the Policies tab. If this is something you will use often, saving the policy as a template can also help speed things up for future profiles.
Hope that helps!
3 months ago Dec 22, 2025
Thanks, that definitely helps.
One more thing, sometimes I need to compare two policies to make sure nothing has changed, or export a policy to review it with my team. Is that possible?
Hi,
At the moment, Hexnode doesn’t support exporting or comparing policies. I will have this shared with our team as a feature request.
Thanks for bringing this up, and feel free to reach out if you have more questions!
