I know this sounds silly, but I’ve forgot my local admin credentials on some enrolled Macs at my workplace. I was assigned to change the passwords of some devices and that’s when I hit a brick wall knowing that I’ve forgot the admin credentials. Is there any way I could overcome this?
Changing macOS passwords without local admin credentialsSolved
Tags
2 months ago
Jan 16, 2026
Hey @eliiza , don’t worry, you have a way around that. Just create a new admin account on the devices from your Hexnode portal, as a temporary admin. Then, you can use its credentials to reset the devices’ password. After you’ve done this, you can delete the temporary admin account after its use.
2 months ago
Jan 16, 2026
Can you guide me to do this briefly?
2 months ago
Jan 16, 2026
@eliiza , sure thing. Head over to your Hexnode portal. Go to Manage > Devices and select your devices. Then, go to Actions > Policies & Accounts > Create User Account. While configuring the settings, set the Account Type to Administrator.
If you have any more queries, just drop them down below! You can also check out our help docs regarding creating accounts on macOS devices.
