Can’t deploy hexnode store apps via policySolved
1 month ago Mar 01, 2026
I was trying to install a couple of apps from the Hexnode Store on our Windows devices, but when I try to configure the policy, it doesn’t seem to give me the option. I also tried to create an app group with these Hexnode Store apps, but I still wasn’t able to.
Funny enough, when I try to install the same apps from the Hexnode Store individually using the Install application remote action, there is no issue. Is this a bug?
1 month ago Mar 03, 2026
Hey @wilma,
I hate to break it to you, but we don’t currently support the installation of Hexnode Store apps via the Required Apps policy, nor can they be included in App Groups.
Right now, we only support installing them using the Install Application remote action. Additionally, you also have the option to use our Automation feature if you’d like to schedule this remote action and deploy the apps across your devices automatically.
If you have any more questions, just let me know!
Cheers,
Eden Pierce
