Can trackpad settings be locked on macOS using UEM?Solved
3 months ago Dec 22, 2025
Hey everyone! I’m looking to block users from changing trackpad settings on our macOS devices. Is there any way to do this?
Hi @sybylla . Unfortunately, macOS doesn’t allow trackpad settings to be locked individually. This is because Apple doesn’t expose trackpad preferences as a manageable restriction through UEM.
3 months ago Dec 23, 2025
Exactly, @marien . But, @sybylla , as a workaround, you can block access to the System Settings app. By blocklisting System Settings, users won’t be able to modify any system preferences—including trackpad settings.
3 months ago Dec 24, 2025
We ran into the same requirement in our environment. Blocking System Settings worked well for shared and kiosk-style Macs, but for user-assigned devices, it may impact usability, so it’s worth considering the use case.
