Hello @sammyy,
This behavior typically occurs when Developer Mode has been restricted through a device policy in Hexnode UEM.
When the Developer Mode option is disabled in the policy applied to a device, users cannot enable Developer Options from the device setting, even if they tap the Build Number multiple times.
To allow access, you can modify the assigned policy using the following steps:
- Navigate to Manage > Devices.
- Select the affected device.
- Open the Policy tab and click on the policy currently assigned to the device.
- Click Manage > Modify.
- Go to Restrictions > Advanced.
- Under Allow Settings, locate Developer Mode and enable it.
- Save and deploy the policy so the change is pushed to the device.
Once the device receives the updated policy, the user should be able to enable Developer Options normally.
