App installation failing on iOSSolved
2 months ago Jan 26, 2026
Hi, applications are not installing on a newly added iPhone, including the Hexnode app.
Replies (7)
2 months ago Jan 27, 2026
Are you pushing the app through Required Apps policy?
Usually, you’ll need VPP licenses for it, or the user has to be signed in with an Apple ID.
Yeah, it’s using Required Apps and the device has both. Normally Hexnode installs automatically during setup, right?
Just noticed it says the VPP token is expired though.
2 months ago Jan 28, 2026
That would do it. You will need to renew the VPP token.
Also worth checking Manage > Device > Action History to see if there are any app install errors.
How do you renew the VPP token again?
1 month ago Jan 28, 2026
Hi @cameron, thanks for reaching out.
To renew the VPP token, please refer to the documentation below:
https://www.hexnode.com/mobile-device-management/help/renew-vpp-token-in-hexnode-mdm/
When I go to Apps and Books, I don’t see Content Tokens.
Update: Never mind, missed a step
It’s working now, thanks!
