App configuration for Hexnode Kiosk BrowserSolved
4 months ago Oct 23, 2025
Hey everyone, I’m managing Android tablets in a school where students are taking exams. I need to make sure they can’t use Incognito mode to bypass browsing restrictions during the test. Is there a way to completely disable Incognito mode in Hexnode Kiosk Browser?
Hey @verbnigge , I understand your concern, and Hexnode has a solution! Along with Website Kiosk, you can make use of the App Configurations feature.  Here’s how:
  1. Under Policies > Android > App Management, go to App Configurations.
  2. Click on +Add App Configuration and select Hexnode Kiosk Browser from the list.
  3. Disable the Incognito mode availability option from the settings and click Done.
  4. Apply the policy to the targeted devices.
4 months ago Oct 24, 2025
Thanks, @isabel_lora ! That’s sounds simple! But a quick question — if a student tries to open Incognito manually after this, will it actually be blocked, or does it just hide the option?
@finn , I tried this myself following @isabel_lora ‘s steps. The option is completely disabled. They can’t open incognito at all. It’s not just hiding the button; the feature is fully blocked.
4 months ago Oct 25, 2025
Awesome! I just tested it on a few Android tablets, and it works flawlessly. Incognito mode is completely blocked. Finally, a reliable way to enforce browsing restrictions without having to monitor every device manually! Thank you all.
