Any shortcut for sound settings on macSolved
11 months ago May 04, 2025
Hi all,
I recently switched from an Asus zenbook to an m2 pro running macOS sequoia 15.4.1. Loving it so far, but there’s one thing that’s been a bit annoying. I often need to switch audio inputs and outputs or adjust volume settings, and going through System Settings >> Sound each time is kind of tedious.
Is there a faster way to do it?
11 months ago May 06, 2025
First of all, welcome to the Mac world, buddy!
You could actually pin the sound settings to the menu bar. Go to Control center settings and enable sound option as “Always Show in Menu Bar”.
Something else you can try, and I’m not sure if you’re familiar with Spotlight search, is to just press cmd + space to open it and search for sound. Press enter, and voila, it opens.
11 months ago May 09, 2025
Can’t you use the Shortcuts app to configure some shortcuts for it?
11 months ago May 15, 2025
I don’t think so, correct me if i am wrong. Once i  tried to do it for a specific setting (display) in system settings, but I couldn’t really figure out how to do it.
Later, I found out you can easily open it by option + clicking the increase or decrease brightness button a couple of times.
I think the same applies to sound settings as well. Just try option + increase sound or decrease sound or mute button (option +f10 or f11 or f12).
11 months ago May 20, 2025
Ohh okay, this works for me. Thank you.
