Windows device sleeps before configured timeoutSolved
10 months ago Jun 18, 2025
Hi everyone,
We are facing a strange issue with one of our Windows 10 devices and I’m hoping someone can help throw some light on it. We had set up several policies to prevent the device from sleeping such as, the auto-lock was configured via password policy to trigger after 10 minutes, and the unattended sleep timeout was set to 5 minutes through the power policy.
Despite these settings, the device kept going to sleep after just a minute of inactivity. Any ideas what might be causing this issue?
Could there be any other policies or scripts configured, such as those related to sleep mode or screensavers?
10 months ago Jun 19, 2025
We do have a screensaver policy enabled, but we didn’t think it would affect sleep behavior. It’s just configured to activate after 1 minute of inactivity.
I think that might be the issue. I figure it has something to do with how the screensaver timeout interacts with the sleep settings.
10 months ago Jun 20, 2025
This does seem to happen on Windows, sometimes the device auto-locks based on the screensaver timeout set in screensaver policy, regardless of other settings. Increasing the timeout value for the screensaver is usually a good workaround.
9 months ago Jun 27, 2025
I’ve seen this happen before. Some laptops use something called Modern Standby, which can ignore your sleep settings. Try running powercfg /a in Command Prompt to check.
Also, check if any programs from your laptop brand (like Dell or Lenovo) are changing the sleep settings.
