What’s with “Ops-ification” of everything now?Solved
2 months ago Feb 12, 2026
Hey everyone, I was curious about a topic I’d like to discuss. I’m seeing “Ops” attached to every department lately. I get DevOps, but now I am seeing people with MLOps and BizOps. Is this just corporate rebranding, or are these actually distinct career paths? How do they even overlap?
2 months ago Feb 13, 2026
There’s a logic to it. Think of Ops as the bridge between creation and stability.
  • DevOps bridged the gap between writing code and running servers.
  • MLOps bridges the gap between a data scientist’s experimental model and a reliable production API.
  • BizOps bridges the gap between high-level strategy and daily execution.
The common thread is automation and feedback loops. If you’re manually doing the same task twice, someone is going to turn it into an Ops role.
2 months ago Feb 14, 2026
To jump in on the MLOps side—it’s definitely not just rebranding. Training a model is the easy part. The nightmare starts when your data drifts or your model’s accuracy tanks in the wild.
In MLOps, we deal with things DevOps doesn’t usually touch, like Model Versioning and Feature Stores. If a standard app crashes, you get a 500 error. If an ML model breaks, it might still return a result, it’s just a wrong result. We build the systems to catch that.
2 months ago Feb 15, 2026
Funny enough, BizOps is probably the most “human” of the bunch. While the other Ops roles are focused on code and data pipelines, BizOps is about process pipelines.
We look at the business as a machine. If Sales isn’t talking to Product, that’s a bug. We use data to find where the company is leaking money or missing opportunities. It’s basically Internal Consulting but you actually have to stick around to fix what you broke.
1 month ago Feb 16, 2026
Unpopular opinion: It’s all just Systems Thinking. Whether you’re deploying a container (DevOps), a neural net (MLOps), or a new pricing strategy (BizOps), you’re just trying to create a repeatable, scalable process.
Here’s a quick cheat sheet for the OP:
Type Core Goal Key Toolset
DevOps Ship code faster/safer CI/CD, Kubernetes, Terraform
MLOps Reliable AI deployment PyTorch, MLflow, Data Lakes
BizOps Operational efficiency SQL, Tableau, CRM, ERP
FinOps Cloud cost optimization AWS Cost Explorer, Finout
