What exactly are TCC and PPPC on macOS, and how do IT admins use them in managed environments?Solved
1 day ago Mar 29, 2026
Hey everyone, I’m trying to wrap my head around TCC and PPPC on macOS. I know Apple uses TCC to control app permissions (camera, mic, disk access, etc.), but how exactly does PPPC fit in when we’re managing devices with Hexnode or Jamf? Can someone explain it like I’m new to this?
Replies (7)
Sure thing. Think of TCC as the gatekeeper on macOS. It’s the framework that decides whether an app can access sensitive resources. By default, it always asks the user.
PPPC profiles are what MDM/UEM solutions (like HexnodeJamf, Kandji) use to pre-approve or deny those prompts. For example, you can push a PPPC profile that says “Allow Zoom to use the microphone” so the user doesn’t get nagged with pop-ups.
Well adding to that: PPPC is basically Apple’s way of letting IT admins automate some of those TCC decisions. But not all. For example:
  • Accessibility → Can be allowed via PPPC.
  • Full Disk Access → Can be allowed.
  • Screen Recording → Nope. Apple forces the user to toggle that one manually.
So PPPC is powerful, but it’s not a silver bullet.
Exactly. And that’s where scripts come in. We’ve had cases where Zoom or Teams updates break existing permissions. The PPPC profile is still there, but macOS doesn’t recognize it. Running a script with tccutil reset clears the stale record so the UEM policy re-applies cleanly.
But why aint you guys talking about that one thing to remember.Apps must be closed for TCC resets to take effect. If you’re resetting Zoom, add killall “zoom.us” at the start of your script. Otherwise, the reset won’t register until the next restart.
23 hours ago Mar 29, 2026
We also use scripts for auditing Full Disk Access. Sometimes users complain that our endpoint security tool isn’t working, and it’s because FDA wasn’t applied correctly.
21 hours ago Mar 29, 2026
Important caveat: Apple’s System Integrity Protection (SIP) limits what you can do. You can’t bypass user consent for things like Screen Recording or Camera. Scripts can only reset or audit, not force-enable. That’s by design, Apple wants the user in control of the most sensitive stuff.
20 hours ago Mar 29, 2026
Got it. So basically:
  • TCC = the framework.
  • PPPC = the MDM/UEM way to pre-approve some permissions.
  • Scripts = the “surgical tools” for resets, audits, and workarounds.
Makes sense now. Thanks everyone!
