Hey all,
I was going through the remote actions list and noticed something called Update eSIM. Haven’t really used it before. What does it actually do?
Hey all,
Oh yeah, we’ve used that a bit. It’s for managing eSIM profiles remotely. Like, if you need to activate a new plan or refresh an existing one, this action helps trigger that from the portal itself. The device reaches out to the carrier’s server and pulls the updated eSIM profile over the air.
In our case, we use it for field devices. Whenever a data plan expires or needs to be switched to a different carrier plan, we just trigger this action instead of asking the user to do anything manually. We had to get an SM-DP+ server URL from our provider for it to work, so that part is important.
Nice. Any idea which platforms support this?
We’ve only tried it on iPhones so far, so not really sure beyond that.
Hey everyone,
The Update eSIM remote action is supported on iOS devices running version 13.0 or later.
If you need further assistance, feel free to reach out to us.
