Unusually high data consumption by Hexnode – Is it the Location Scan?Solved
4 weeks ago Mar 09, 2026
Hi everyone,
We ran into an issue with a specific batch of deployed devices, and I’m hoping someone here can help. We operate on a very tight network bandwidth, and lately, we’ve noticed a massive spike in data usage on these devices.
We pulled reports from our network carrier, and they’ve confirmed that the Hexnode app appears to be the one consuming the bulk of this data—around 200MB to 300MB per device.
Our team’s working theory is that this is tied to the “Scan Device Location” action. We have it running frequently for these field devices, and we are guessing that every time this command executes, it’s pulling a heavy amount of data.
Has anyone else experienced this? Is there a way to optimize the location tracking so it doesn’t eat through our data plans? We really need a solution for this as soon as possible.
Thanks in advance!
Hello,
Thank you for reaching out to Hexnode Connect! I completely understand your concern; managing devices on a strict bandwidth budget is challenging, and unexpected data spikes can certainly be alarming.
I’d like to help clarify how our location tracking works and offer some insight into what might actually be happening here.
To address your team’s theory: a single Scan Device Location ping consumes roughly 5KB of data. Even with highly frequent tracking intervals throughout the month, this action is incredibly lightweight and is significantly lower than the 200-300MB range you are seeing.
I want to assure you that the Hexnode app’s routine background syncs and core operations are not the cause of a data surge of this magnitude. When carriers report high data usage under an MDM app, it is almost always indicative of large data movement commands being routed through the MDM, rather than the app’s baseline functionality.
I highly recommend re-assessing the data usage patterns and recent action histories for that specific set of devices. The data leak is likely stemming from:
  • App Installations or Updates: Pushing large enterprise applications or app updates to these devices.
  • OS Updates: Automated or forced OS updates being downloaded.
  • File Syncing: Pushing heavy media files, documents, or scripts to the devices via Hexnode.
Next troubleshooting steps:
Take a look at the Action History in your Hexnode portal for the devices in question during the timeframe reported by your carrier. Check if any bulk app deployments or OS update policies were executed.
We are always here to help you get to the bottom of this. Please feel free to reach out if you have any further queries, need assistance looking through your portal logs, or if you’d like to share any ideas and feedback here on Hexnode Connect.
George,
