Support for File Management actions in Hexnode APISolved
2 hours ago Mar 25, 2026
We’ve expanded the Hexnode API with robust file management capabilities, offering more flexibility in deploying and removing files across your endpoints.
What’s new?
The API now supports the following enhancements:
  • Deploy file – Enables you to send files to a specific destination path on targeted devices, users, device groups, or user groups.
  • Remove file – Allows you to command targeted endpoints to remotely delete specified file paths and directories.
These enhancements provide IT admins with greater control and a streamlined, programmatic approach to file distribution and cleanup, improving the overall device management experience.
Do check out our File Management API documentation for more details. For any questions or feedback, reach out to us at support@hexnode.com or connect with us on Hexnode Connect.
Cheers,
George
