So… fileless malware is a thing now?Solved
4 months ago Dec 01, 2025
I came across an article about fileless malware and I’m confused. How do you even have malware without a file? I always thought viruses needed to install something before causing damage. If anyone can break it down in normal human language, that would help.
4 months ago Dec 03, 2025
It’s a fair question. Traditional malware usually drops files on your disk, which makes it easier to spot and block.
Fileless malware skips that part. It runs directly in memory and uses built-in tools like PowerShell to execute whatever the attacker wants. Nothing gets written to the drive, so your antivirus doesn’t see the usual red flags.
It’s basically the difference between someone breaking into your house by smashing a window versus someone walking in through an unlocked door and acting like they belong there.
4 months ago Dec 04, 2025
What makes it dangerous is how subtle it is. Because it uses legitimate system tools, the activity doesn’t look obviously malicious at first glance. And since nothing is saved as a file, restarting the system wipes most of the evidence.
Ordinary malware leaves a footprint you can track. Fileless malware leaves almost none, which is why security teams worry about it so much. It forces you to watch behaviour instead of scanning for known bad files.
