Samsung XCover roaming blocked by default – how to force "All Networks"?Solved
1 month ago Feb 19, 2026
We’re deploying Samsung XCover 6Pro/7 devices with global SIMs, but they keep defaulting to National Roaming Only“, blocking data abroad. This effectively kills data connectivity for our field teams as soon as they cross a border until someone manually goes into settings and changes it. We’ve pushed the APNs via Hexnode, but the roaming scope remains restricted, and users can’t change it manually.
Is there a way to remotely force the roaming scope to All Networks?
Hey @skylar-a , this is a common hurdle with global SIM deployments. Standard MDM protocols often don’t have a “one-click” toggle for roaming scope because it is considered a carrier-privileged setting. However, since you are using Samsung devices, you can solve this using OEMConfig (Knox Service Plugin)Here’s a breakdown of the steps to fix it:
  1. Check APN Protocol: Ensure your Hexnode APN policy is set to IPv4/IPv6. IPv4-only can sometimes trigger “National Roaming” restrictions.
  1. Use KSP: Configure the Knox Service Plugin policy in Hexnode. In the App Configuration, locate the Roaming Scope setting and set it to All Networks“.
  1. KPE License: This feature requires a Knox Platform for Enterprise (KPE) Premium key. You can generate this for free from the Samsung Knox Admin Portal and paste it into the license field in your KSP configuration.
1 month ago Feb 20, 2026
Thanks! Where do I get that KPE key, and where does it go in the Hexnode policy?
No problem! Here is the quick path:
  • Get the Key: Log into the Samsung Knox Admin Portal, go to License Keys > Generate License Key, and select Knox Platform for Enterprise (KPE).
  • Apply in Hexnode UEM: In the Hexnode UEM portal,  under the Knox Service Plug-in (KSP) policy, paste that alphanumeric string into the Knox License Key field.
  • Set Scope: Within the same KSP config, find Device Connectivity and switch Roaming Scope to All Networks (International Roaming).
Test this on one device first, the modem usually takes about a minute to update once the policy hits.
