OS Update policy behaviour?Solved
2 months ago Jan 01, 2026
Hi everyone,
We’re managing Android tablets with Hexnode and currently have a 30-day OS update postponement policy applied.
A couple of things we’re trying to understand:
  • Is there any way to see which devices have OS updates pending or how many days are left in the postponement period?
  • What actually happens once the postponement period ends? Do updates automatically become available or does something else need to happen?
Most of these devices are running in kiosk mode. We’ve added com.android.settings to background apps so update notifications can show, but users still can’t manually trigger updates. It feels like admin control is still in effect.
We know removing the Scheduled Os updates policy allows manual updates, but we’d like to understand the expected behaviour when the postponement policy remains applied.
Any insights would be helpful.
2 months ago Jan 02, 2026
Hey @douglas
We’ve been running android devices with Hexnode for quite some time, and this topic comes up often.
From what we’ve seen, there isn’t really a way in the console to view pending OS updates or track how much postponement time is left. Android doesn’t seem to expose that information back to the management layer, so the postponement works more like a holding period than something you can actively monitor.
On the postponement behaviour itself, our understanding is that hexnode’s role is limited to deferring updates for the configured window. It doesn’t schedule or trigger an install once that window ends. After postponement expires, Hexnode is essentially no longer blocking the update, but what happens next is still handled by Android and the device manufacturer.
In practice, that means updates don’t automatically install just because postponement ends. Whether the update shows up again, prompts the user, or requires manual interaction varies by OEM and device model.
Kiosk mode adds another layer. Allowing com.android.settings in Background Apps can help surface update related screens or notifications, but it doesn’t necessarily give users the ability to initiate updates while admin level restrictions are still in place.
We’ve generally treated postponement as a way to delay updates during a control window, not as a way to manage or automate the update flow end to end. The rest tends to depend on how Android and the OEM handle updates on that device.
Hope that helps based on what we’ve observed.
