New in Automate: App Distribution for Windows devicesSolved
9 months ago Jul 03, 2025
We’re excited to roll out a powerful new feature in Hexnode’s Automation tab: introducing the App Distribution action for Windows devices!
This new capability allows you to automate app deployment across your Windows fleet with complete control over how installations are configured and managed.
Here’s what you can do:
  1. Script support: Run scripts at key stages – before installation, after installation, or even post-deployment for auditing and other tasks.
  2. Custom install settings: Choose how apps are installed – add extra install parameters, define success criteria, and set how return codes should be handled.
  3. Smart return code handling: Set up automated actions (like restarting a device or re-running a script) based on specific return codes, helping ensure smoother, more reliable installations.
This is a game-changer for managing large-scale app deployments, improving installation success rates, and saving time for IT teams.
Need help getting started?
Check out our help document for a complete walkthrough.
Still have questions? Drop us a line at support@hexnode.com or connect with us on Hexnode Connect.
Ben Clarke
