Need help with retrieving device ID!!Solved
3 weeks ago Jan 15, 2026
Hey everyone, I’m building an app that needs to pair a Hexnode-enrolled device with a specific user. I wanted to check if there is a way to retrieve the device IDs of the enrolled devices from the Hexnode portal so we can use it for device–user pairing in our app?
Hey @arthur , yes, you can definitely retrieve Device IDs from Hexnode. You have two main options to do this:
  • From the Reports tab in the Hexnode portal:
    • Go to the Reports > Built-in Reports section.
    • Here, you can view and export device details, including the Device ID along with the associated user.
  • Using Hexnode APIs:
You can fetch device details, including the Device ID, using Hexnode’s REST APIs.
This is useful if you want to automate the device–user pairing in your app.
That sounds good. But I’m currently in a place with really bad reception, and I’m having trouble navigating the portal properly.
Could you please share the documentation links for both the Reports section and the APIs so I can check them later?
Sure, no problem! Here are the relevant links:
Reports Documentation: Manage Built-in reports in Hexnode UEM
API Documentation: Hexnode API Documentation
These will walk you through how to access device details from Reports and how to fetch them using APIs.
Thank you so much, @kylian_parker !
