Minimum device count for Hexnode licensesSolved
4 weeks ago Jan 12, 2026
Hi folks, I’m planning to manage just 3 devices for my team at the moment. While checking the pricing details, I noticed that Hexnode has a minimum license requirement of 15 devices.
Is there any option to purchase fewer licenses? Or do I need to go ahead with 15 licenses even if I don’t plan to use them all right now?
Hello @mike_johnson , thank you for reaching out us!!
Please note that Hexnode follows a minimum licensing requirement of 15 devices, which serves as our base package.
You are not required to enroll all 15 devices immediately. You can begin managing any number of devices between 1 and 15, depending on your current needs. The remaining licenses will remain available for future use as your device fleet expands.
Thanks for clarifying! Just to confirm although I’ll be purchasing 15 licenses, I can start by enrolling those 3 devices and add more later when needed, right?
That is correct. You can start your deployment with just 3 devices right away. As your requirements grow, you can enroll additional devices using the remaining licenses without any extra configuration or delays.
If you require any further assistance, please feel free to contact our support team at support@hexnode.com.
Clara sterling,
Hexnode UEM.
