We’ve been manually deploying OS updates across our devices, but it’s getting harder to manage as we scale. Came across zero-touch OS updates, are they actually better, or is manual still the safer option?
Manual OS updates vs Zero-Touch automation — what actually works better?Solved
Tags
Replies (7)
Manual is still better in my opinion. You get full control, test updates, pick devices, and roll it out gradually. With full automation, if a buggy update drops, it hits every device at once, and you’ve got a company-wide outage on your hands.
We thought the same initially, but manual didn’t hold up for us. Devices were spread across teams, people kept postponing updates since we let users choose when to restart, and they just… never did. We ended up with inconsistent versions everywhere.
But what about risky updates? You can’t just blindly deploy everything.
We don’t. We still test updates separately. But once we’re confident, zero-touch handles the rollout. Manual just couldn’t keep up with the volume.
Makes sense. So you’re not fully replacing manual then?
No, we still use manual for testing or edge cases. But for regular updates across the fleet, zero-touch made things way easier.
Fair enough, thanks for sharing your views, folks!
