Is White Glove IT actually scalable?Solved
2 months ago Feb 04, 2026
We’ve been asked to provide “white glove” IT support for execs and a few leadership devices. Faster response, proactive monitoring, zero downtime – the usual expectations.
Is this actually scalable?
Replies (6)
2 months ago Feb 05, 2026
I think the confusion comes from how loosely the term gets used. Vendors say “white glove” and it sounds like someone is physically hovering over the device 24/7. That’s not realistic.
I used to think it was mostly marketing. But honestly, not all users or devices carry the same risk. Exec laptops, finance teams, R&D, those aren’t “standard helpdesk queue” devices. If you strip the buzzword away, it’s really about controlled prioritization.
2 months ago Feb 06, 2026
Exactly. It’s not magic. It’s just structured flow: collect device data, monitor for specific triggers, escalate fast, remediate immediately. If you define the workflow clearly, you can absolutely orchestrate it.
So it’s more about process maturity than anything?
Right. You need segmentation first, identify which users/devices qualify as important. Then build automation around them.
If you’re using something like Hexnode, you can isolate leadership devices into their own dynamic groups, apply stricter compliance baselines, monitor them more aggressively, and connect alerts with higher priority tags. That removes the dependency on someone “remembering” that this is an executive laptop.
And I guess that’s the key difference, it becomes system-driven, not person-dependent.
