Is it possible to configure multiple SSIDs for Windows?Solved
4 weeks ago Feb 26, 2026
Can we add multiple SSIDs for Windows, like we can for macOS and Linux in Hexnode?
 I don’t think that’s possible. As far as I know, Windows only supports one SSID per policy.
Thankyou for raising this question.
That’s correct. As of now, Windows allows only one SSID per policy. If you want to configure more than one SSID, you’ll need to create multiple policies and push them to the device.
Yes it did work for me but it is a lil too complex. Hopefully, Windows will support multiple SSIDs in a single policy in the future.
