Introducing Hexnode XDRSolved
1 month ago Feb 17, 2026
Security should not live in a separate silo away from device management. Hexnode XDR bridges the gap, allowing you to bring monitoring, investigation, and response into the same ecosystem as your managed devices.
By integrating Hexnode XDR with your UEM instance, you no longer need to switch between disconnected tools to understand what happened on a device and how to fix it. You can detect, investigate, and act from a unified workflow, streamlining your security operations.
Flexible Deployment & Integration
  • Compatible with Any Environment Hexnode XDR is a robust security solution designed to work with any management infrastructure. You can deploy the XDR agent using your current UEM to gain immediate visibility and protection on your devices.
  • Optimized for Hexnode UEM Pairing Hexnode XDR with Hexnode UEM unlocks native integration capabilities. Since both products share the same ecosystem, they work together to provide a streamlined and unified experience.
Key Capabilities
  • Centralized Security Dashboard Get a live overview of your security posture. Instantly visualize incident trends, severity distributions, and MITRE ATT&CK categorized events to spot instability at a glance.
  • Streamlined Incident Response Move from detection to mitigation without leaving the console. Inspect attack process trees, kill malicious processes, isolate endpoints, quarantine files, or launch a remote terminal session to fix the device immediately.
  • Advanced Threat Hunting Go beyond basic alerts with the Investigate tab. Use query-based searches to scour endpoint activity, validate suspicious behavior, and hunt down hidden threats across your fleet.
  • Unified Policy Management Configure essential security behaviors directly from the console. You can schedule Microsoft Defender scans, define device inactivity rules, and control remote terminal access to ensure security settings align with your operational needs.
Hexnode XDR unifies visibility, investigation, and response in a single console, so administrators no longer need separate workflows to understand and act on security events.
Ready to get started?
Visit www.hexnode.com/xdr/ to learn more or contact support@hexnode.com for purchase and licensing inquiries.
Cheers,
Eden Pierce
Hexnode
