How to Import contacts?Solved
3 months ago Jan 07, 2026
Hey guys! I was tryna import contacts into a device using Hexnode, but I can’t find the option anywhere. Can someone help me out?
Hmm, I poked around the device settings myself once. Honestly, I thought it would be tucked away in some advanced menu, but I couldn’t spot it either.
From my side, I vaguely recall something about uploading files. Maybe it was a .vcf format? Not sure if that was for contacts or something else though.
Thank you for your input, everyone.
Here’s the way to do it: Log into the Hexnode Portal, go to Manage > Devices, select the devices you want to import contacts into, click Actions > Import Contact to device, upload the .vcf file containing your contacts, and finally click Import to push the contacts to the device.
Ohhh, so the trick is to select the device first and then look under Actions. I was digging in the wrong place entirely.
And the .vcf requirement is good to know. I’ll need to export my contacts into that format before trying. Thanks for clearing it up!
