How do you quickly wipe multiple compromised devices in Hexnode?Solved
6 hours ago Apr 10, 2026
Hey people, if multiple devices are compromised at the same time, what’s the fastest way to wipe all of them using Hexnode? Is there a way to trigger it in one go instead of handling devices one by one?
3 hours ago Apr 10, 2026
@bram, you definitely don’t want to be handling that one device at a time in a real incident. The quickest way is to group them and trigger the action once. Here’s how most admins handle it:
  • First, in the Hexnode UEM portal, go to Manage > Devices and select all the affected devices.
  • Then use Actions → Groups & Domains > Add devices to group and create a temporary group (something obvious like “INCIDENT” so you don’t miss it).
 Once that’s done:
  • Go to Manage > Device Groups
  • Open that group
  • Hit Actions > Security > Wipe Device
 That sends the wipe command to all devices at once.
 One thing to keep in mindthis works best if the devices are still online. If a device is offline, the command will queue and execute when it reconnects. Also, if you’re doing anything that cuts network access (like scripts), make sure the wipe command is sent first. Otherwise, the device might never receive it.
2 hours ago Apr 10, 2026
Thanks for this!
