How do I deploy apps to a specific user?Solved
1 month ago Feb 12, 2026
 Hey people, I’m trying to deploy a few apps to a specific user because some apps seem to be missing on their devices during setup. What’s the best way to do this from the Hexnode portal?
1 month ago Feb 13, 2026
@penelope , you can do this directly by executing the Install Application remote action from the Hexnode portal. Navigate to Manage > Users, select the user you want, and then click Actions > Applications > Install Application. From there, choose the required apps and click Install. The selected apps will be pushed to all devices associated with that user.
Thanks, exactly what I needed!
