Our Linux fleet has grown quite a bit, and we’re starting to see configuration drift across devices. Small changes add up over time, and manual fixes don’t really hold. Curious how others are dealing with this without constant manual intervention?
How are teams handling Linux config drift at scale?Solved
2 months ago
Feb 10, 2026
Yeah, same story here. We fix something, it looks fine for a bit, and then a few weeks later it’s out of sync again.
2 months ago
Feb 10, 2026
Exactly. We’ve got scripts, but unless someone remembers to rerun them, things slowly drift back.
2 months ago
Feb 10, 2026
Hi all!
What usually works is stopping one-off fixes and making them repeatable.
With Hexnode, teams typically:
- Push Bash scripts using Execute Custom Script instead of running commands manually.
- Set up Hexnode Automate so those scripts re-run when devices check in or fall out of compliance.
- Use Action History and Action Reports to confirm what ran and where, without logging into devices.
That way, if a Linux device drifts, it just gets corrected automatically the next time it connects.
2 months ago
Feb 11, 2026
That actually clicks. We’re scripting, but we’re not enforcing anything.
1 month ago
Feb 11, 2026
Yep, same mistake we made early on. Once we let automation handle it, drift stopped being a daily headache.
